I can not find surface editing tools (add line, remove line, rise/lower surface) on 2012 ribbon, where can I find them on c3d 2012 ribbon?
Thank You
GZE
As long as you have the Contextual Ribbons enabled, just select the surface in the drawing and the Ribbon should switch to the Surface modify Tab. Then on the right side of the Modify panel is Edit Surface.
To get the Surface modify Tab without the contextual ribbon, select the Modify tab, on the Ground Data panle select Surface, the Surface modify Tab will now be displayed.
Unless it has been improved in 2012, I have found in 2011 that the some things are better accessed via the ribbon and other via Prospector. Unfortunately, no way of knowing until your drawing has crashed/stopped responding.....!!!!!!
