There is a graphics failure - ie, the program gives up displaying the
surface because of something. Is it repeatable?
If so, send it to Support.
I've seen it, and had it happen to me, but I can't get it to repeat -
which tells me it is a memory or video memory resource issue.
Matthew Anderson, PE
sjlidster wrote:
> Ive created a pretty large surface using points and breaklines. When I try to swap edges I get to do 2 or 3 and then the surface disappears. I then have to restart Autocad to make it visible again. Regenerating or changing the style do not bring it back up. I am working in Civil 3D 2009. Has anyone else come across this? It seems to just be a graphics issue as the actual surface is not being deleted.
