Hello All,
I have a surface in Civil 3D which when I opened today is not displaying. All it shows is to border of the surface. I know the surface is there because it is still listed under prospector view and the points are still there. I have tried all the usual things; checked contour layers is on, checked contour interval etc. Can anyone help? Screen shot below:
http://screencast.com/t/siCqzvbifv
regards
Solved by neilyj666. Go to Solution.
Mark Green
Working on Civil 3D in Canada
I had this issue yesterday, i deleted the border from the surface and my contours came back. it was a small surface so instead of attaching a border, i manually eddited the surface to end were i wanted. I know this is not an answer as to the why, but i hope it helps.
Dave
Thanks for the replies everyone. Will try these things at work tomorrow and let you know how I get on. I opened the file on my home PC and can see the surface no problem. So its not the file thats the problem.
Neilyj,
Problem solved - was the level of detail. Turned it off and surface re-appeared. Thanks all.
