Civil 3D Forum
Surface disapeared in Civil 3D
7 REPLIES 7
Message 1 of 8
owen_feeney
466 Views, 7 Replies
Hello All,
I have a surface in Civil 3D which when I opened today is not displaying. All it shows is to border of the surface. I know the surface is there because it is still listed under prospector view and the points are still there. I have tried all the usual things; checked contour layers is on, checked contour interval etc. Can anyone help? Screen shot below:
http://screencast.com/t/siCqzvbifv
regards
7 REPLIES 7
Message 2 of 8
troma
in reply to: owen_feeney
What is is set to display in the style?
Mark Green
Working on Civil 3D in Canada
Message 3 of 8
in reply to: troma
I had this issue yesterday, i deleted the border from the surface and my contours came back. it was a small surface so instead of attaching a border, i manually eddited the surface to end were i wanted. I know this is not an answer as to the why, but i hope it helps.
Dave
Message 4 of 8
neilyj666
You have Level Of Detail switched on which may be the culprit.....
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 8
owen_feeney
Thanks for the replies everyone. Will try these things at work tomorrow and let you know how I get on. I opened the file on my home PC and can see the surface no problem. So its not the file thats the problem.
Message 6 of 8
neilyj666
is level of detail on in the home pc file?
Message 7 of 8
owen_feeney
Neilyj,
Problem solved - was the level of detail. Turned it off and surface re-appeared. Thanks all.
Message 8 of 8
neilyj666
Glad that worked for you
Rail Community
