Civil 3D Forum
Surface creation
1 REPLY 1
130 Views, 1 Reply
Surface creation
I’ve noticed that in Civil 3D, creating a surface from contour data requires turning off / removing all data but the contours as there is no option to “select contours by layer” as in LDDT.
Am I missing something obvious?
1 REPLY 1
Howdy - Unfortunately this is a known limitation with R2005. We've got this listed as a requirement for future releases. For now you can isolate the layer OR use the AutoCAD selection set functionality (ie, build a selection set before running the command and then use the selection set when promoted to select plines). Thanks DAS "RDW" wrote in message news:12021516.1102005211102.JavaMail.jive@jiveforum1.autodesk.com... > I've noticed that in Civil 3D, creating a surface from contour data requires turning off / removing all data but the contours as there is no option to "select contours by layer" as in LDDT. > > Am I missing something obvious?
Rail Community
