I'm using Civil 2012 to create a surface for a landfill. I have UTM coordinates, and my elevations range from about 71m to 115m. When I create my surface using the points, I check the Surface Properties/Statistics, it appears the X,Y & Z coordinates have been scaled down by 3 decimal places. I'm using UTM coordinates to create the points.
Example:
Min elevation = 0.071m .... should be 71m
Min X = 481.510m etc. ... should be 481510.99 or something similar.
Units are set to meters.
Any help greatly appreciated!
-Jason M.
Solved by Jay_B. Go to Solution.
Are the Coordinate Units on Ambient Settings tab of Drawing settings dialog set to meters or mm?
