Dear all,
I have a problem.
My daylight has a 45% slope for cut and fill. I created a corridor surface. When i check the cross section it is touching the exisiting surface within 10 meters. If i check the surface overview, a surface is created even 50 meters.
As you can see on the total overview, the surface is connecting, even if the daylight connects with the exisiting surface already.
I hope somebody can help me
I think i have 'found' the problem..
I've made a cross section with volume calculation..
As you can see on both pictures it touches the Exisiting Surface(red) BUT, the daylight on the assembly that is negative makes a 45 degree slope filling everything that is steeper than 45 degree...
