Civil 3D Forum
Surface corridor goes beyond boundary
5 REPLIES 5
SigridJD
2707 Views, 5 Replies
I have created a ditch/trench corridor and applied a surface to it. It looks fine in the beginning, but then it goes outside the ditch and connects to the bottom of the corridor. The subassembly contains only a ditch.
I would like to know, why it behaves so and what the solution is, to make it follow the corridor alignment only.
Attached is a pic of the corridor surface and of the assembly.
Thanx
5 REPLIES 5
mathewkol
in reply to: SigridJD
Any surface, corridor or regular, needs an outer voundary. It would appear yours has no boundary applied. In the corridor surfaces dialog, there is a boundaries tab. Apply the corridor extents as the boundary is usually the best and easiest way.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
SigridJD
in reply to: mathewkol
Hi Matt, Thanks for the fast reply.
I have attached screenshot of the surface- and boundary settings. The boundary is set to extent, but maybe I need to do more settings ?
mathewkol
That's the correct boundary type.  If any part of your corridor crosses itself, such as a tight insser radius, your boundary may have problems.  Can you attach the DWG?
Matt Kolberg
SigridJD
Smiley Happy Hi Matt,
Thank you very much. The corridor crossed it , because of a too small radius.
mathewkol
I'm glad to have helped you out.  I guess now you just need to figure out how to fix the corridor.  Or, you could maybe use the Interactive boundary tool to create the boundary.
Matt Kolberg
Rail Community
