Civil 3D Forum
Surface contour radius
6 REPLIES 6
RAY629
796 Views, 6 Replies
When I grade from a feature line the contours have a zero radius where they change direction, is there a way to make them have a radius
This is just a straight feature line with no curves and I am grading to a suface. The contours leave the feature line at about 45 degrees but with
a zero radius
6 REPLIES 6
tcorey
in reply to: RAY629
Post a screenshot so we understand what you're saying...
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
wfberry
in reply to: RAY629
Do you have nodes along the feature line or just have beginning and end?
Bill
kcobabe
in reply to: RAY629
I think I understand what you are asking and the answer is no.
The reason there is not a radius on the contours is because contours are made from lines.  If you would like to smooth them you can go into the style and use the smoothing.  I would suggest staying away from splines though.  Splines really don't tell exactly how the surface is going to lay and if you get an engineer that is really particular about the slopes and the way the contours are shown.....  Well you are going to give yourself a big headache.
Now if you really want to make you drawing clean you can do what I do and use user contours to smooth everything out.  Pick the top elevation that follows the entire curve and the bottom and add a polyline curve to smooth it out.  This works well when working with Landscape architects since they like the "Pretty" contours.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Joe-Bouza
in reply to: RAY629
Perhaps a radii in the feature line will get you closer.
additionally, contour smoothing on to some level, and finally, Smooth surface.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
RAY629
in reply to: Joe-Bouza
From what I am hearing here and other places the answer is no I cannot radius the contours the way I want
Thanks to everyone for your time and input
Joe-Bouza
in reply to: RAY629
That is not true
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Rail Community
