Civil 3D Forum
Surface Contour Problems
8 REPLIES 8
Message 1 of 9
dbussie
1623 Views, 8 Replies
I have added contours to my surface (the blue lines).  For some reason the surface generated contour (the orange line) is jumping across the contours I've added.  I'm sure there is a setting or something that I'm missing.  Please see attached screenshots.
Thank you!
Desirea
Civil 3d 2014
8 REPLIES 8
Message 2 of 9
in reply to: dbussie
I think that's your weeding factor.
Message 3 of 9
neilyj666
Take a look at this blog by Brian Hailey http://civil3dplus.wordpress.com/2011/08/13/adding-contours-to-a-surface-youre-doing-it-wrong/
Also look at the weeding and supplementing factors as suggested
BTW - contours are the least robust method of building a surface but if they are all you have....
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 4 of 9
dbussie
in reply to: neilyj666
Thank you.  The blog was very helpful.
Message 5 of 9
dbussie
It looks like I'm still having some trouble with this.  I'm attaching the file with the trouble areas circled in red.  I would appreciate any help I can get.  Not sure why this is happening.
Thanks.
Message 6 of 9
neilyj666
I tried it with just the blue contours and reduced the supplementing and weeding factors and it looks ok to me....
Message 7 of 9
dbussie
What did you drop them to?  I thought I tried doing that and had the same result.  I will try again.
Message 8 of 9
neilyj666
It's on the screenshot - it's usually a bit iterative to get the contours to look correct; hence my previous comment about contours being the least favoured objects with which to build surfaces
Message 9 of 9
dbussie
Sorry, I didn't notice the attachment.
Unfortunately, the engineer didn't provide much for us to use other than a couple of spots and contours.
Rail Community
