Civil 3D Forum
Surface contour label direction
6 REPLIES 6
Fuscha
1712 Views, 6 Replies
Hi, so I want my surface contour labels to be in 90° to the line they are attached to. All I found yet is "view" "world coordinate" and "object" in the label settings (behavior). Are there any possibilities to rotate them 90°?
6 REPLIES 6
sirjoelsph
in reply to: Fuscha
You're almost there.  One tab over from where that setting is - set the rotation angle to 90 degrees under the text element.  You'll most likely want to set that orientation reference to Object also.
-JOEL
neilyj666
in reply to: Fuscha
I'm interested to know why you want them like this?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Fuscha
in reply to: Fuscha
I think you missunderstood me 🙂
I don't need the text 90° to the contour lines I need it 90° to the line which i draw for the location of the labels so that all the labels have the same direction because I dont like if every text has its own rotation.
I put a screeneshot in the attachments so you can see what i mean (i know they are not exactly parallel)
neilyj666
in reply to: Fuscha
I see what you are trying to do now....I'm not sure if it is possible to do this though
sirjoelsph
in reply to: neilyj666
I agree with Neil.  I don't think there is a way to do exactly what you want.  I think the best you could do is set the orientation reference to world and then specify the rotation angle you're looking for.  This will at least get them to all look the same rotation, even though they might not be exactly perpendicular to your line.
-JOEL
Fuscha
in reply to: sirjoelsph
yeah I already thought that there is no solution especially for my question
@sirjoelsph yes I think that might be the best way thanks!
Rail Community
