Hi guys
If you have trial pit/borehole data then you can use the sampled depths at the correct locations to get a stripped surface see http://civilintentions.blogspot.co.uk/2012/05/creating-geological-surfaces-from.html
There are a couple of workaround ways to get the formation surfaces (this is my preferred method http://ericchappell.blogspot.co.uk/2012/01/magical-way-to-calculate-volumes.html) - how much have you used Civil 3D and what was the other software you used?
only have used autocad before. if you can link to tutorials or point me in the right direction.
other software was a QS software that can generate cut and fill, but its very long winded and bad interface to see how the ground shaped, just inputting millions of levels and crossing fingers
