When building surfaces, especially from contours, the panorama window often pops up with a message about data not being added because of crossing breaklines. The zoom function will take me there and I can OFTEN immediately see what line is crossing, but the other 50% of the time, I can't see anything that is causing the error.
Why doesn't the zoom function highlight the point that is causing the problem, similar to the way that the boundary closed poly line function will have a cross on the point of the poly line that is causing the problem?
2014 - Added in 2015?
That sounds like a nice feature request.
I can't tell you how often (if at all) it's been reported to them. But if nobody reports it (such as assuming that someone else already has), then they'll never know about it -- and the more people who DO report it, the more chance it'll get fixed/added.
Bug reports/feature requests can be sent at the following address.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
And if you're on subscription, I'd also open a support ticket reporting the bug/feature request that way too.
Don Ireland
Engineering Design Technician
