Civil 3D Forum
Surface and volume calculation
2 REPLIES 2
nayanakantha843
478 Views, 2 Replies
I attach picture 1 and 2. please see it
i need crate surface like this pictuire 2.
i need crate surface by joining 1, 2, 3 like as picture 2 section
but when i crating surface its joining as picture.
this problem have been found
i crated a tofo of the rock which rock is bend lower picture 2 section
to calculate the volume i need the surfce crate like this.
please anyone can replay for slove this dout or another method for calculate volume
2 REPLIES 2
JSpell
in reply to: nayanakantha843
You won't be able to have a single surface with multiple z values.  Triangulation shape is horizontal only, so this doesn't allow for a single over lapping surface.  I would stick with multiple surfaces and try to make that work.
neilyj666
in reply to: JSpell
You may find some guidance here http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesCUG/GUID-B75FEF9F-1020-4E66-B1B4-196732B... but you will need to split the surface you have into two; upper and lower
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
