Civil 3D Forum
Superimposed profile
3 REPLIES 3
mkt
1422 Views, 3 Replies
Hi
I have a problem with superimposing a profile to a profile view. The problem is that it only shows part of the superimposed profile. I believe the attached images speak for themselves.
It appears that it only superimposes the spiral, but why should that matter?
Win 7
Civil 3D 2015
Tags (2)
3 REPLIES 3
troma
in reply to: mkt
I'd have to see a closer look at the station values in plan and profile. But I suspect that one alignment isn't long enough to see the next PVI of the superimposed profile, so the superimposed profile gets truncated at the last visible PVI.
Mark Green
Working on Civil 3D in Canada
mkt
in reply to: troma
You might be right, but that would make the tool useless in almost every situation.
I also encountered another problem. When I use MarkPoint and LinkToMarkedPoint it doesn't connect at all. The distance varies, but some places the distance is as much as 60 cm. The corridor also seems to make some weird connections between the assemble and the offset assembly.
All help is greately appriciated.
You can get the dwg file from  https://dl.dropboxusercontent.com/u/649020/Superimposed.dwg
Bill_Myron
in reply to: mkt
The Alignment you are Superimposing the Profile into must be long enough for the PVI's of the Profile to be displayed in.
Just extend your Secondary Alignment To the extents of the PVI's and mask the parts of the Alignment you do no want to see.
Rail Community
