Is there any way to do that (walkaround method)
Thank you.
Solved by onsionsi1. Go to Solution.
Home tab of the Ribbon, Create/Design panel. Look for the Profile drop down menu and drop it down. There is a command to create a profile from a corridor feature. Create this profile and select the profile. The contextual profile ribbon appears.Hit the Superimpose button and select your target profile view.
John Mayo
Thank you Mr.John for your effort.
Actually we cann't to Superimpose Corridor feature profile but i figure out the walkaround method.
That you can create alignment from corridor featureline and then create a profile for this alignment.
Eventually you can superimpose these profile.
Thank you
