Civil 3D Forum
superelevation
3 REPLIES 3
343 Views, 3 Replies
superelevation
The cross sections do not display the correct cross slope for superelevated sections. I have redefined the templates and regions and checked the SE parameters. I have also edited the design control for each individual section. Still, the cross slope is not correct. Does anyone have any points or tips for additional settings I may have missed, or has anyone experienced the same problem? Any input would be welcome.
3 REPLIES 3
Beth, You're in the wrong newsgroup. This one is for the new Civil 3D program - which doesn't have road sections yet. Try posting to the autodesk.land-desktop newsgroup. Glen "Beth Schatz" wrote in message news:11740739.1077189348914.JavaMail.jive@jiveforum2.autodesk.com... > The cross sections do not display the correct cross slope for superelevated sections. I have redefined the templates and regions and checked the SE parameters. I have also edited the design control for each individual section. Still, the cross slope is not correct. Does anyone have any points or tips for additional settings I may have missed, or has anyone experienced the same problem? Any input would be welcome.
Hi Beth, When you Edit the Design Control for individual sections, the software assumes you know what you are doing and does not calculate those sections. [Cross-sections][Design control][Reset Design Control] will remove all your hand editing and allow the system to compute the Super-elevation. If your super-elevation is still not showing then there will be an error somewhere in your setup of the super-elevation. -- Laurie Comerford CADApps www.cadapps.com.au "Beth Schatz" wrote in message news:11740739.1077189348914.JavaMail.jive@jiveforum2.autodesk.com... > The cross sections do not display the correct cross slope for superelevated sections. I have redefined the templates and regions and checked the SE parameters. I have also edited the design control for each individual section. Still, the cross slope is not correct. Does anyone have any points or tips for additional settings I may have missed, or has anyone experienced the same problem? Any input would be welcome.
Are you using the "Process Sections" after editing the design control? "Beth Schatz" wrote in message news:11740739.1077189348914.JavaMail.jive@jiveforum2.autodesk.com... | The cross sections do not display the correct cross slope for superelevated sections. I have redefined the templates and regions and checked the SE parameters. I have also edited the design control for each individual section. Still, the cross slope is not correct. Does anyone have any points or tips for additional settings I may have missed, or has anyone experienced the same problem? Any input would be welcome.
Rail Community
