Hi Beth,
When you Edit the Design Control for individual sections, the software
assumes you know what you are doing and does not calculate those sections.
[Cross-sections][Design control][Reset Design Control] will remove all your
hand editing and allow the system to compute the Super-elevation.
If your super-elevation is still not showing then there will be an error
somewhere in your setup of the super-elevation.
Laurie Comerford
CADApps
www.cadapps.com.au
"Beth Schatz" wrote in message
news:11740739.1077189348914.JavaMail.jive@jiveforum2.autodesk.com...
> The cross sections do not display the correct cross slope for
superelevated sections. I have redefined the templates and regions and
checked the SE parameters. I have also edited the design control for each
individual section. Still, the cross slope is not correct. Does anyone have
any points or tips for additional settings I may have missed, or has anyone
experienced the same problem? Any input would be welcome.
