Civil 3D Forum
Superelevation with no curves
5 REPLIES 5
4465 Views, 5 Replies
I'm working on a runway in Civil 3D 2011. I want to transition cross slopes along the runway. i.e. 1.5% for sta 1+00 to 10+00 and then transition into 1.0%. I thought superelevation would be the best way to do this (I dont want any actual superelevation, just transitions in cross slope). When I select the alignment and "Calculate/Edit Superelevation" i get the following message in the commmang line: "_AeccCalcEditSuperelevation No superelevation data has been calculated for the selected reference alignment." It does not bring up the wizard.
My runway alignment doesn't have any curves and I'm thinking that's the problem. Is is possible to create superlevation without curves? Am I missing something? If this wont work, what's the best way to accomplish my goal?
Tags (1)
5 REPLIES 5
KMercier_C3D
I haven't tried it myself but as soon as I read your question I said to myself "I just saw a blog post about that exact topic." And sure enough I did, take a look here.
Good luck!
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
in reply to: KMercier_C3D
Thanks for the rely! According to the video I can make superelevation in an aligmentent with no curves as long as there is a alignment segment before and and after the point at which I want the transition. In other words, there has to be a PI at the transition.
My issue was actually that I was trying to add superelevation in my corridor drawing when my aligment lived in a different drawing  and was data shortcuted into my corridor drawing.
The previous link is disabled
Good luck!
to read "Make the superelevation on a straight alignment" article
follow this link http://civilfastforward.com
jking
To get around the problem of no SE dialog box/wizard, I removed the short-cutted alignment from the corridor drawing and copied and pasted the alignment from the alignment drawing into the corridor drawing.
JWK
www.gmbnet.com
Civil3D 2013 - Win 7 - 64-bit
KirkWM
Wow still helpful even today. My work's firewall blocked the site but the video is on youtube, link for the next person: https://youtu.be/pgjTo_OhOQs
Rail Community
