I would like to provide field staff stationing where the grade changes along the slope. i.e. 0% =1+00 -1%= 2+00 -2%= 3+00. -3 = 4+00and so on.
Any ideas would be helpful...Thanks
Welcome to the board Brian.
I'm not sure that I understand what you're trying to do. Do you want some sort of a report showing the slopes at intervals along the road, or do you just want the critical superelevation stations? There are methods for showing super along a profile, or labels that can be displayed in plan view, or various reports.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
A Superelevation report can be generated for the alignment by exporting data from the tabular editor.
Select Alignment > Modify Panel on Ribbon > Superelevation drop down > view tabular editor > Export superelevation data.
Another option would be to create a Superelvation View, Tutorial file Superelevation-5.dwg has an example.
You can also use the "Lane Slope Report" from the toolbox-Corridor and save to excel so you can get rid of any columns you don't want.
See image
