Civil 3D Forum
SuperElevation Not Respoding
12 REPLIES 12
Message 1 of 13
bozoli
1522 Views, 12 Replies
Hi Evedryone,
I have a problem with my superelevation. everything is calculated accordingly but when i build my surface from corridor after i have calculated superelevation it does not show the results. Even my cross sections view still show a normal assembly cross section. It happaned on both C3d2011 and ad C3d3013. What might seem to be the problem?..its really frastratingSmiley Sad
thanx in advance
Bozoli
12 REPLIES 12
Message 2 of 13
BrianHailey
in reply to: bozoli
In your subassembly properties, make sure they are using the superelevation that you want them to use.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 13
onsionsi1
in reply to: bozoli
Make sure that you used Subassembley that applied superelevation like Pavement Generic as i can remember the name of it.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
Message 4 of 13
bozoli
in reply to: onsionsi1
i have attached a pdf of my drawing in here,..and by checking the longsection u can see that there is superlevation but my contour surface still shows a normal cross section on the plan.
Message 5 of 13
wfberry
in reply to: bozoli
You say you have calculated the levels properly but your levels left and right do not reflect any "super" even though your diagram seems OK.
Bill
Message 6 of 13
bozoli
in reply to: wfberry
Bill,
this is exactly my problem, i have calculated "super" and the diagram seem OK, but when i road surface shows as if i have never calculated any "superelevation". because my left and right levels i have to read them from my road surface. this is really what frustrate me.
Bozoli
Message 7 of 13
BrianHailey
in reply to: bozoli
Have you gone into your subassembly properties and told your lanes to use the super elevation? If you don't do that, no super elevation will be applied.
GEI Consultants
My Civil 3D Blog
Message 8 of 13
bozoli
in reply to: BrianHailey
Brian, maybe what you saying could be the problem. Can you please take me through on how do i tell my Subassembly lanes to use supaerelevation cause i cant seem to find that option the Subassembly Properties.
thanx
Message 9 of 13
onsionsi1
in reply to: bozoli
Here are the guide to apply SE through Subassembley
1- create assembley and rename it as you want
2- Go to tool palettes (Subassmbley)
3- Select GenericPavementStructure Subassembley
4- It will applied one of the edge of subassembley and may be by defualt in the right
5- select the subassembley (GenericPavementStructure) and right click
6- select the subassembley properties
7- Go to parameters and at the (Use superelevation slope) select Right Outside Lane if the Lane is right or vise versa
Hopefully it will be clear for you.
Thank you
Message 10 of 13
bozoli
Great..Problem solved,
Much appreciated for input guys..moving ryte along.
Message 11 of 13
Lisa_Pohlmeyer
in reply to: bozoli
I've run into this as well. Most of my roadways are two lanes and I've had to make sure the pavement section parameters are set to outside lanes.  Not sure I understand the logic, but it works.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 12 of 13
bozoli
in reply to: Lisa_Pohlmeyer
Very much rite Lisa,
there problem with my subassembly lanes was because i used LaneInsideSuper instead of LanesOutsideSuper. it was jus a choice of the correct subassebmly that got me stuck for two days.
Message 13 of 13
LeafRiders
in reply to: bozoli
I had a similar issue on this end, thanks to those who post on these boards to help others troubleshoot similar hang ups. Much appreciated everyone!
Rail Community
