Back in the LDD and sheetmanager days, we had our sheetmanager template setup to create a band for superelevation that identified the key points of the superelevation using appropriate blocks and station labels. The appearance of the block differed based on the direction of the curve (see attached drawing). This use to work as you were able to identify different labels based on the curve direction. I can't seem to do the same with Civil3D. Anyone have any suggestions as we have come to like this band style over the years?
