Civil 3D Forum
Superelevation Attainment Methods Questions
1 REPLY 1
daog
1120 Views, 1 Reply
I am setup Design Criteria Editor,
but I have problem for create formula for this conditions,
- Crowned pavement revolved about the inner edge
- Crowned pavement revolved about the outer edge
anybody can help me or give me something ideas with this problem.
regards, daniel
Edited by: daog on Feb 23, 2009 12:37 PM
Please, see attached image (Case II and III) Edited by: daog on Mar 2, 2009 2:11 PM
1 REPLY 1
mspatz
in reply to: daog
As far as I'm aware C3D does NOT have an automatic setting for rotating about the inside or outside edge. It only automatically supers about the CL; automatically at least. If you want to rotate about the inside \ outside edge you have to do it manually with offset alignments and profiles and figure out the transition lengths \ slopes yourself.
Not the end of the world but crazy since you are expecting it to just be a toggle. LDT had it and all you had to do was choose a method for rotation. I wrote this off as something forgotten and will be added as folks complain and versions are refined.
Rail Community
