Hi Everyone.
I am currently working with Civil 3D and noticed my road edge profile do not reflect the slopes of a superelevation since some right and left edge points should be higher or lower than the centerline.I have attached my civil 3d file. I would really appreciate if you could help me with this one. Thanks in advance.
Godfrey
Godfrey,
In order for Civil 3d to apply the superelevation the "Use Superelevation" Parameter must be specified within all subassemblies related to the superelevation.
Did you apply Use Superelevation Patrameter such as Outside Lane Right & Outside Lane Left etc. to each of the 2 subassemblies on the Right & Left?
Also did you Rebuild the Corridor?
It seems to honor the superelevation you've provided in your dwg correctly here when I complete all the above steps.
Godfrey,
Take a look at the attached dwg.
Hi Jay_B
Thank you for your help. I am now able to do it. Sorry for my late reply.
Godfrey.
