The LaneSuperelevationAOR should work, you may find this Being Civil, "When is a Curve Not a Curve?" post helpful.
In the attached sketch the cross slope x% is unkownn and varies with the left and right TC. Hope this clarifes the question.
thanks
In most cases the Assembly marker would be at the centerline referencing the centerline alignment and centerline FG profile and the software calculates the "known" TC values in your sketch. The centerline could easily be derived from these known TC elevations.
Then top of curb profiles are created and shown in profile views etc. for reference.
We have to show top of curb rather than Centerline for certain clients but the entire design is based on centerline, which the software is set up to use as the basepoint for Superelevation IMO.
There might be other ways of going about this but for a superelevated undivided road design such as this, the pivot about centerline works well.
I'm not familiar with MicroStation Geopak Vector slope constraints.
If you're simply trying to fit/warp this superelevation between left and right (fixed) constraint then create Lt & Rt. edge of pavement profiles by copying the TC profiles you have and use the raise/lower to lower them the `0.5 or whatever and Target these edges of pavement with the LaneSuperelevationAOR subbassembly or any suitable lane sub. which supports "outside elevation" target parameters.
These are then targeted from within Corridor Properties on the Parameters tab.
Still going to need the centerline fg profile assigned at assembly marker in this case.
