I have been requested to change our 4% max SE to 3% I though I could simply go into TE and change all the 4% to 3%.
1. it take a long time for each cell edit ( even though my corridor has rebuild off)
2. I was able to change the numbers in the first curve but it will not let change the others; I can type in the cell but it keeps reverting to 4%
is there a particular way it should be done?
would it be easier to delete and reconmpute?
Joe Bouza
Solved by Joe-Bouza. Go to Solution.
Joe Bouza
