Civil 3D Forum
Super Elevation max slope at 2%?
3 REPLIES 3
1081 Views, 3 Replies
All,
I am using Civil 3d 2013 and I am trying to calculate the superelevation information in which the curve will max at 2%. Is there a way in which the superelevation can be calculated using the superelevation wizard in which a 2% SE is the max? So far it will only let me use the SE for 4% local roads and I have to edit it using the SE layout.
Any advice or steps will be greatly appreciated.
Thanks!
-Lucas
3 REPLIES 3
Jay_B
2% is a standard crown slope and C3d the tables used are based on AASHTO design standards.
From AASHTO_ "Maximum superelevation rates of 4% and 6% are for urban areas."
Since at 2% there aren't major issues with rollover, friction and sliding this may be why the wizard
won't accept a value less than 4% as max.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
sboon
Rather than using the tabular editor for adjusting superelevation you can do it  with grip edits in a Superelevation view.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
sboon
in reply to: sboon
The data used for superelevation calculations is stored in xml files here:
C:\ProgramData\Autodesk\C3D 2012\enu\Data\Corridor Design Standards\Metric or Imperial\
With some work you can edit a copy of one of these files to create your own table with the values you want.
Steve
Rail Community
