Am designing a rural road with many transition curves, I have set 100% superelevation runoff on spiral curve. This works fine but supelevation runoff doesnt begins at the begining of the spiral (TS) as seen in the attached image, i know this can be adjusted manualy but there are so many curves is there a way or any trick to make superelevation runoff begins exactly at the begining of spiral curve?
We use three criterias to calculate spiral length this problem appears when superelevation runoff is not the critical determinant of spiral length.
Not sure that I understand - you want the length of superelevation transition to match the length of spiral?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
I dont want the transition to match with the spiral, I want transition to begin at the begining of the spirar as per attached image. Currently full super elevation is attained at the begining of the curve I want it to be attained even within a spiral if the spiral length is longer than the required superelevation runoff.
Select an alignment then open the Design Criteria Editor from the context ribbon. From there you should be able to open the xml file which is used to calculate various values used for superelevation, among other things. If you expand on the Superelevation Attainment Methods group you can see the formulas used to calculate the various lenghts.
For more detailed information you should locate and open the same xml file in a text editor. You will find comments added to the file which explain the formulas and variables.
Steve
Hi, GZE
Did you manage to get the runoff to start at the begining of the spiral? I have the same problem trying to get round it.
yes i found a solution
i used _"Autodesk Civil 3D 2012 Road Design Standards UKIE" with few modifications to suit our standards
