Civil 3D Forum
Super Elevation and Horizontal Transitions
1 REPLY 1
t_mckenzie
611 Views, 1 Reply
I need some help with getting a roadway to transition horizontally for a turn lane. If it were straight without super, it would be easy. However, the transition happens in a curve that needs to be super elevated.
I know I can use the lane transition assembly and set it to "change offset and grade" but with that, I would have to manually calc my EOP elevations.
Is there a sub assembly with the ability to use the centerline super elevation data as well as transistion horizontally? Any other ideas?
Using C3D 09
-Tucker McKenzie
1 REPLY 1
t_mckenzie
in reply to: t_mckenzie
Sorry, should have checked the subassembly catlog. There is a super elevation with varying width in there. Our standards has a tool pallette that has paired down some of the additional sub assemblies, and it wasn't in there.
Anyways ... sorry and thanks!
-Tucker
Rail Community
