Civil 3D Forum
Suite versions of software
50 REPLIES 50
Message 1 of 51
neilyj666
1110 Views, 50 Replies
My understanding is that the version of Map that civil 3d is built on isn't quite the full standalone version.
what are the differences between the software in the infrastructure design site premium compared to the standalone versions e.g raster design, 3ds, revit structure and how much practical difference do any differences make?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
50 REPLIES 50
Message 41 of 51
hfindley
in reply to: Cadguru42
If you have not received your opt out email you can contact your reseller and they should be able to send you the link.
Message 42 of 51
claudio.ruschel
in reply to: DarrenP
Autocad Civil 3d Help includes Autocad Map 3d Help, where there´s a topic "Working with Industry Models". But the templates and workspaces of these features are not included in Civil 3d. Even if one copy the templates manually from the installer, feature creation is disabled. We bought Civil 3d considering that this software includes whole Map 3d. Is there a documentation that explains how Autodesk made such mess?
Tags (1)
Message 43 of 51
There is no documentation I know of on this subject. Unfortunately some commands and whole portions of Map 3D conflict with Civil 3D. The way this has been handled is to disable the conflicting portions of Map within Civil. I've pointed out to Autodesk that when they combined the Map help files with the Civil 3D help files. They did not remove the disabled commands. The answer I received didn't show any concern over this.
A good place for getting a comparison might be with your reseller
In order to get the full version of Map 3D. You need to buy Infrastructure Design Suite (any version). That will include the complete Map 3D program.
Allen Jessup
Allen Jessup
CAD Manager - Designer
Message 44 of 51
neilyj666
in reply to: claudio.ruschel
It is perhaps a bit disingeuous of Autodesk to say that civil 3d is built on Map but not the to mention it is, in fact, Map LT ....
Message 45 of 51
AllenJessup
in reply to: neilyj666
Not that I disagree with you. However LDT was originally built on full Map. I believe that the earlier versions of Civil 3D were also with only a few disabled commands. Now a lot of Map overlaps Civil functions. Things like they both will import point clouds. Of course in Autodesk fashion the way Map handles point clouds is not the same way Civil does. So Map point clouds are disabled in Civil 3D.
I would be nice if they could go back and reconcile these conflicts. But often the way a GIS user would expect a process to work is vastly different than a Civil / Survey user.
I do agree that the portions of Map that are disabled in Civil should be listed in a obvious place.
Allen
Allen Jessup
Message 46 of 51
Cadguru42
I've always wondered why Autodesk hasn't been sued for false advertising regarding this.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 47 of 51
dgorsman
Not sure how that would apply?  Do they state anywhere that it is fully functional Map3D other than "... based on..."?  And the simple "no guarantee that it will do what you want it to" clause in the EULA puts a full stop to that line of thinking.
Message 48 of 51
neilyj666
in reply to: dgorsman
I'd suggest that the EULA is pretty watertight as regards any possible user litigation .....
Message 49 of 51
Cadguru42
That's true, except in order to get to the EULA you have to purchase and install it, unless you got the trial.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 50 of 51
claudio.ruschel
It is a real problem in my company.
I have users that needs more features from AutoCAD Map than Civil.
But we decided to upgrade all users to Civil considering that these Map users would be supplied with the solution, and now I see we were fooled by Autodesk´s information omission and a lack of integration between the architectural, commercial and documentational team. It seems they really don´t know the mess that was created: Civil help includes features that are not available.
A solution that Autodesk would supply to this issue is to develop an installer like the InfraStructure suite; that installs Civil and AutoCad Map as separate products.
Message 51 of 51
Well. They already have Infrastructure Design Suite. So I doubt that's going to happen.
Did you deal with a reseller on this upgrade. They should have asked your requirements and made it clear that all the functions of Map wouldn't be included.
Maybe if you go back to them and outline the trouble that this has caused. They might be able to give a good deal on IDS.
Allen
Allen Jessup
Rail Community
