Civil 3D Forum
Suggestions needed for template maintenance
4 REPLIES 4
dslocum
187 Views, 4 Replies
Does anyone have any suggestions on how to keep the Civil 3D template drawing up to date? As I work in projects I tend to make new styles, layers, layer filters, settings, etc. that I want to be in my template for future use. I know I can save my current project as a .dwt and use it as the template file for the next project, but is that really the proper work flow? Any suggestions or ideas would be apppreciated.
4 REPLIES 4
kcobabe
in reply to: dslocum
If you go to the "Manage" tab, towards the end you will see an import styles button.  Click that and browse to the file.  You can also open the file and your template and switch to master view in settings, then drag and drop the styles.  Both should work.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Jay_B
I'd recommend reading the Templates, Styles and Drawings section of the Civil 3D Best Practices Guide.This provides a good overview of template setup and the QNEW variable etc.
Create Templates and place them in a central location on a read only network if others need access.
Then update them with your new Styles & Layers as needed.
Creating and maintaining a clean dwt essential to efficient use of Civil 3D IMO.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
neilyj666
in reply to: Jay_B
If I create a useful new style/label/layer, I'll copy it to my template for use in the next drawing I create via QNEW.
I tend to keep everything in one template (backed up to Autodesk 360 - at last a use for the Cloud....!!!) but not sure how practical it would be to use different templates for different projects as inevitably the style/label you need is in the "other" template
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
dslocum
in reply to: neilyj666
Thanks! I'll give that a try.
Rail Community
