Not often I ask for help and from reading through previous posts I'm not the only one having trouble with this.
I have a complex corridor which has lanes disappearing and starting different codes etc along the length and some codes are causing me a headache. See attached image: The issue is arising between two regions (first region has two lanes left second three lanes left).
I am having issues with the featureline branching options, currently set to Inward as outward creates even more anomalies.
How can I force the model to correctly join these featurelines and stop thinking for its self?
I have tried adding in custom points and adding a 1m break between the two regions and relocating them all to no avail.
Has anyone got any suggestions?
I have requested a "No branching" Option in the corridor featureline props to eliminate this issue. I don't want it to think for itself in this case, just place a featureline with a code where I specify.
R2010 - SP2-SAP.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
