Civil 3D Forum
Subscription Content to Ribbon
10 REPLIES 10
Message 1 of 11
neilyj666
570 Views, 10 Replies
All my Subsription Content is currently accessed via the Toolbox in Toolspace.
Can this content be put on a Ribbon panel (under the Plug Ins tab for example as in screenshot) for ease of access?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
10 REPLIES 10
Message 2 of 11
tcorey
in reply to: neilyj666
Absolutely.
Just open CUI and make new commands whose macros call the same commands that are called when you execute from the Toolbox tab. Once the new commands are made, they can be drag onto panels (existing or new.)
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 11
neilyj666
thanks Tim, i thought it would be possible. I'll try it on Monday and post back if i run into problems
Message 4 of 11
neilyj666
Attached some toolbox screenshots of the items I want to put on the ribbon, I'm not entirely sure what command/macro goes where and would be grateful for some guidance.
Message 5 of 11
MikeEvansUK
Neil, as these are external commands you will need to add new commands into the CUI for this.
As Civil3d is aware of the commands this makes life a bit easier so add the command to the interface Rbd & Genioimport etc, however I'm not sure how you will get it into the Tab as I haven't had to do this yet Iv'e only done this by creating a Toolbar and converting it to a ribbon.
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 6 of 11
tcorey
Here's a video on how to do that, Neil. As an added bonus, I also show you how to fix your mistake when you type the command name wrong the first time.Smiley Wink
http://www.youtube.com/watch?v=NNOA83G64nU
Best regards,
Tim
Tim Corey
Redding, CA
Message 7 of 11
neilyj666
in reply to: tcorey
Tim, many thanks for taking the time to do the video - it's much essier to follow the CUI steps via this method.
I've a few other routines that I'll also put on the Riboon now....
Message 8 of 11
neilyj666
Typing RBD only seems to work after running the importer from the toolbox first - does something else need to be loaded on startup??
Message 9 of 11
tcorey
Sorry, I didn't even check that. Use this code for the macro:
^C^C(command "netload" "C://ProgramData//Autodesk//C3D 2013//enu//Data//Reports//Net//boreholes.dll");rbd;
That will work if you are using the default Data directory for Civil 3D. If not, you'll need to replace the folder structure in this command.
Tim Corey
Redding, CA
Message 10 of 11
neilyj666
in reply to: tcorey
No problem - thanks for the revised code line
Message 11 of 11
neilyj666
Tim
The posted code works great but how would it need to be amended to use vlx or lsp commands.
I know I can load at Startup but I prefer to only load the tools I need all the time at startup and other less frequently used ones  as and when I need them
Rail Community
