neilyj
Message 1 of 11 (327 Views)
Subscription Content to Ribbon
327 Views, 10 Replies
11-09-2012 01:23 AM
All my Subsription Content is currently accessed via the Toolbox in Toolspace.
Can this content be put on a Ribbon panel (under the Plug Ins tab for example as in screenshot) for ease of access?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
tcorey
Message 2 of 11 (298 Views)
Re: Subscription Content to Ribbon
11-09-2012 03:49 PM in reply to: neilyj
Absolutely.
Just open CUI and make new commands whose macros call the same commands that are called when you execute from the Toolbox tab. Once the new commands are made, they can be drag onto panels (existing or new.)
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
neilyj
Message 3 of 11 (285 Views)
11-10-2012 01:34 AM in reply to: neilyj
thanks Tim, i thought it would be possible. I'll try it on Monday and post back if i run into problems
neilyj
neilyj
Message 4 of 11 (264 Views)
11-11-2012 12:07 PM in reply to: neilyj
Attached some toolbox screenshots of the items I want to put on the ribbon, I'm not entirely sure what command/macro goes where and would be grateful for some guidance.
neilyj
mikeevans
Message 5 of 11 (250 Views)
11-12-2012 02:12 AM in reply to: neilyj
Neil, as these are external commands you will need to add new commands into the CUI for this.
As Civil3d is aware of the commands this makes life a bit easier so add the command to the interface Rbd & Genioimport etc, however I'm not sure how you will get it into the Tab as I haven't had to do this yet Iv'e only done this by creating a Toolbar and converting it to a ribbon.
Mike
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
tcorey
Message 6 of 11 (230 Views)
11-12-2012 11:11 AM in reply to: neilyj
Here's a video on how to do that, Neil. As an added bonus, I also show you how to fix your mistake when you type the command name wrong the first time.:smileywink:
http://www.youtube.com/watch?v=NNOA83G64nU
Best regards,
Tim
Tim Corey, Owner
Redding, CA
neilyj
Message 7 of 11 (224 Views)
11-12-2012 01:57 PM in reply to: tcorey
Tim, many thanks for taking the time to do the video - it's much essier to follow the CUI steps via this method.
I've a few other routines that I'll also put on the Riboon now....
neilyj
neilyj
Message 8 of 11 (194 Views)
11-13-2012 04:27 AM in reply to: neilyj
Typing RBD only seems to work after running the importer from the toolbox first - does something else need to be loaded on startup??
neilyj
tcorey
Message 9 of 11 (181 Views)
11-13-2012 08:27 AM in reply to: neilyj
Sorry, I didn't even check that. Use this code for the macro:
^C^C(command "netload" "C://ProgramData//Autodesk//C3D 2013//enu//Data//Reports//Net//boreholes.dll");rbd;
That will work if you are using the default Data directory for Civil 3D. If not, you'll need to replace the folder structure in this command.
Tim Corey, Owner
Redding, CA
neilyj
Message 10 of 11 (178 Views)
11-13-2012 08:43 AM in reply to: tcorey
No problem - thanks for the revised code line
neilyj
