Hi all,
Have a question about simplying intersection design within subdivisions. I've tried the intersection wizard - and while a great tool, I can't get it to preform the design I need it to. I've been able to replicate the design needed through feature lines, but it takes many features and is a timely process. When you have quite a few intersections within each development, it would be nice to have a quicker way of modeling each.
The design I'd like to streamline is a warped intersection, where the crown of the through road is maintained and the street (local) intersecting centerline and lower curb/gutter line is warped 50' prior to the valley gutter of the through road (please see the attached PDF).
Is there a setting I am missing when using the wizard to create this type of warp? When I run the wizard, the intersecting street maintains it's crown up until the curb return which is much closer than the desired 50'. Or, is there a way to streamline the process without needing to create multiple (7) feature lines? Any insight, or feedback on how the community models these intersections would be greatly appreciated. Thanks to all!
You are stuck with having to create profiles for the edge of pavement, use super elevation or use featureline targets to warp the cross slope. Modeling intersections can be a tedious job in cases where the wizard tool doesn't meet your needs.
Joe Bouza
Joe Bouza
Joe Bouza
