Civil 3D Forum
Subbassembly Composer point markers showing
2 REPLIES 2
ddouglas
357 Views, 2 Replies
This may not be the correct forum for this question, however I'll post it anyway.
I have created a subassembly using the subassembly composer. The assembly works just fine in creating a corridor, sections and volume tables, however the point markers are showing in all of the section views.
Is there a way to turn them off in the section sheets since they make the sheet very crowded and cluttered. I have attached screen shots of the assembly and a section.
Thanks in advance
Don
2 REPLIES 2
mathewkol
in reply to: ddouglas
This depend on if you have named them explicitely in the Comopser. If not, these will be represented by the "Not Coded" (or something like that) styles in the points section of the code set style you have applied to the sections in the views.
If not, assign a no display style to either that code or the default codes also in the code set style.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
ddouglas
Matt,
Thanks for the reply, I tried resetting label styles to <none>, and point codes to Basic or off. Didn't change things. However by going thru "Edit corridor Properties and changing the Object Style to Basic with <None> for label style, the markers did go away.
Sorry I grabed the subassembly and assenbly JPEG's and not the section JPEG, the ones I did attach showed the markers anyway.
Thanks again for your reply
Don
Rail Community
