Civil 3D Forum
Subbassembly composer codes and targets , problem in corridor parameters
1 REPLY 1
Aistis88
284 Views, 1 Reply
I create assemblys using "Autodesk subassembly composer ". I import them and build a corridor from them.   If i make corridor from one assembly with "pave offset target" and other "target to surface" i have to set those targets in corridor. Problem is  - if that corridor have like for example 10 regions, i have to set same targets for  all regions and its is quite difficult , couse usually i have like 2-3 assemblys with different construction but the same targets and like 20-30 regions , so if my corridor  must target pave offset i have to set that SAME target for the right and for the left side 30x2 = 60 times.
Is there any possibility that could remove this misery ?
1 REPLY 1
nilesh33
in reply to: Aistis88
It's same procedure even if you are using autodesk stock subassemblies.
But you can set "Surface Target" for all regions at once by selecting "Set Targets All Targets" in corridor properties.
(Select option click here to set all)
For offset targets, I would suggest you to create one small region with all offset targets and apply this region for full length. Then split this region into smaller once according to your assemblies.
Hope it will help you.
Rail Community
