Civil 3D Forum
Subassembly Windows won't scroll
2 REPLIES 2
tcorey
272 Views, 2 Replies
Has anyone experienced an issue where Subassembly Composer windows won't scroll? I can scroll with the wheel, but the scrollbars don't work.
If I start a new project, they work for a while, but once I have worked for several minutes, they become disabled again.
I did an uninstall and re-install but I get the same results.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
2 REPLIES 2
klaus.schumann
in reply to: tcorey
Hi Tim,
I assume you are referring to the Flowchart pane?
Have you tried clicking ont the Fit to screen button when this happens? If so does it make any change in restoring the scroll bar functionality?
Klaus Schumann
Revit Specialist
tcorey
in reply to: klaus.schumann
Hi Nikki,
Thanks for the response.
This happens in all of the Subassembly Composer windows, and only in Subassembly Composer.
I have created another new project and so far have not had the same issue, so I am good to go for now.
I will follow-up if this happens again.
Best regards,
Tim
Tim Corey
Redding, CA
Rail Community
