Tom,
There are two ways to do this with a secondary alignment, and with a VBA
routine.
With the secondary alignment you would draw that to represent the edge of
pavement with the taper that you need. Of course if you are going around a
curve, this becomes much harder.
With the VBA solution, you would need to take one of the existing lane
assemblies (I would start with the lane outside super) as your starting
point. Read the help file on how to make a new entry in the ATC file, and a
new macro. The modification you would make to the subassembly would be to
add three more parameters to hold the starting station of the transition,
the end station, and the change in the width that you want (you could also
change depths...). Then inside of the VBA code you would check to see if the
section you are working on is inside of the range, if so, you would
calculate the percentage along the section you are, and add that much of the
delta to the width of the lane. In the ATC file, if you give the type info
of the two station variables "6", they will display in station format.
FYI, I'm teaching a class on sub assemblies at AU this year, and this may be
a nice little tutorial for that class...
Cheers,
Peter Funk
API Product Manager
