Civil 3D Forum
Subassembly problem
3 REPLIES 3
om_gc
326 Views, 3 Replies
Subassembly problem
I want the ditch at the bottom of the slope. It keeps on attaching at the EP. My subassembly is attached..
3 REPLIES 3
mathewkol
in reply to: om_gc
Your ditch IS attached to the EP, at least in cut anyway. You have your lane, then a conditional cut, then your ditch.
Ir are you talking about your fill? Looks like you have a daylight then the ditch. It should be working in fill.
The daylight in fill, you'd be better off using the link slope to surface instead. Attaching a subassembly to part of a daylight can be inconsistent.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
sboon
in reply to: om_gc
Not sure, but it almost looks like both of the conditional tests are being evaluated as true, and both daylights are being built.  Matt's solution is probably correct, but you might want to also check the corridor parameters and make sure that the conditional targets are right.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
om_gc
in reply to: sboon
Thanks guys. I followed matt method & it works.
Steve - I chose target and existing surface target as my existing surface.
Rail Community
