I want the ditch at the bottom of the slope. It keeps on attaching at the EP. My subassembly is attached..
Solved by mathewkol. Go to Solution.
Not sure, but it almost looks like both of the conditional tests are being evaluated as true, and both daylights are being built. Matt's solution is probably correct, but you might want to also check the corridor parameters and make sure that the conditional targets are right.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Thanks guys. I followed matt method & it works.
Steve - I chose target and existing surface target as my existing surface.
