Civil 3D Forum
Subassembly Offsets
0 REPLIES 0
Message 1 of 1
86 Views, 0 Replies
Subassembly Offsets
Is a VA required to be associated with Subassembly Offsets? If so, why? A BasicLaneTransition doesn't require one. The solution is found by holding grade, elevations...etc. That solution should be passed to the offset. This would make planar cul-de-sacs much easier, because creating a profile where a plane intersects a multiple curves (bulb and return) is time consuming. Hopefully it's possible. Thanks, Tyler Townes, P.E.
0 REPLIES 0
Rail Community
