Civil 3D Forum
subassembly LINKOFFSETANDELEVATION force link direction
5 REPLIES 5
el.Topo
993 Views, 5 Replies
I am using a LINKOFFSETANDELEVATION subassebly
but I'm having a problem getting the right result
as it links to whatever side it finds the target object nearest
(the target is a polyline that goes around the alignment)
Is there a way to force the link's direction strictly to a specific side, even if the distance to the target is smaller at the opposite side?
thank you
MacBook Pro, Intel Core i7 CPU M 620@2.67GHz, 8GB RAM
W7Pro SP1, 64-bit / Civil3D 2016
5 REPLIES 5
doni49
in reply to: el.Topo
Can you break the target polyline into 2 parts so you'd have a TargetLeft and a TargetRight?
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
el.Topo
in reply to: doni49
in the example as it is in the attached file it would be easy, but in my actual case I would have to define 3 or 4 regions and that may happen that this might occur several times during the design process.
It's a workaround though
I just tried the DaylightToOffset but it behaves the same way unfortunately.
el.Topo
Im sorry to say that this may induce even stranger behaviour... just tried it and it was dissapointing
doni49
Does this image resemble what you need (where the white line is the alignment and the green line is the target)?
Don Ireland
el.Topo
in reply to: doni49
not exactly,
it's the top of a landfill (green = alignment) linking to the toe feature line (yellow)
what you see is what I finally managed ending up with a lane subassembly instead
where you have the option of choosing a side.
there are other ways (not grading though, or it's me not getting along with so good)
but I really need to show these slope patterns, so I had to use a corridor
thnak you for your time
Rail Community
