C3D 2012 SP3
I want to label the subassembly I have created. It is easy enough to create the label style and apply it through the code set styles. I want to drag the labels for pavement depth, creating a leadered situation. Why does the program create multiple labels for each marker or link? Can this be limited to one lable for the marker and link?
If the markers and/or links have multiple codes, you get a label for each code. Adjust your code set style and include all of the marker and link codes. For those where you want no label, set the styletp <none>.
An alternative would be to set the <default> and <no codes> to <none> and add the codes that you want to the list and specify those styles.
