AutoCAD Civil 3D General Discussion
Valued Contributor
raghulan
Message 1 of 5 (377 Views)
Subassembly interaction
377 Views, 4 Replies
11-18-2013 09:12 PM
In civil3D, when two sub-asemblies intetract how to create the sub-assembly to react to to another sub-assebly.
Example
I have a situation where the kerb foundation needs to go under the corridor layers. So its like the corridor layer engulfs the kerb foundation.
So as the parameter of the Kerb fouundation changes the corridor should adjust to.
Raghulan Gowthaman Cert IV TAA, B.E,.
Senior Technical Consultant | Developer - R&D
A2K Technologies Sydney
Web : www.a2ktechnologies.com.au
www.civil3dforum.com | www.e4forums.com
www.zcodia.com.au
www.raghulangowthaman.com
*Expert Elite*
sboon
Message 2 of 5 (336 Views)
Re: Subassembly interaction
11-19-2013 10:11 AM in reply to: raghulan
I believe that what you're trying to do here is not possible with two separate subassemblies.  Once the software has finished inserting the lane sub, and moved onto the curb sub there is no way for it to go back and change the lane.  You would probably have to create something in Subassembly Composer for this.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Valued Contributor
raghulan
Message 3 of 5 (302 Views)
11-24-2013 02:42 PM in reply to: raghulan
Thanks I know that, just wanted to know if there is any work around in achieving that. I can always create a full subassebly integrating kerb foundation and lane together.
www.zcodia.com.au
Valued Mentor
fcernst
Message 4 of 5 (284 Views)
11-25-2013 06:36 AM in reply to: raghulan
just wanted to know if there is any work around in achieving that....
LaneOutsideSuperLayerVaryingWidth
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
www.ernstengineering.com
Valued Contributor
raghulan
Message 5 of 5 (202 Views)
12-04-2013 08:53 PM in reply to: fcernst
 will give it a go.
www.zcodia.com.au
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
