Civil 3D Forum
Subassembly interaction
4 REPLIES 4
raghulan
482 Views, 4 Replies
In civil3D, when two sub-asemblies intetract how to create the sub-assembly to react to to another sub-assebly.
Example
I have a situation where the kerb foundation needs to go under the corridor layers. So its like the corridor layer engulfs the kerb foundation.
So as the parameter of the Kerb fouundation changes the corridor should adjust to.
Raghulan Gowthaman Cert IV TAA, B.E,.
Senior Technical Consultant | Developer - R&D
A2K Technologies Sydney
Web : www.a2ktechnologies.com.au
www.civil3dforum.com | www.e4forums.com
www.zcodia.com.au
www.raghulangowthaman.com
4 REPLIES 4
sboon
in reply to: raghulan
I believe that what you're trying to do here is not possible with two separate subassemblies.  Once the software has finished inserting the lane sub, and moved onto the curb sub there is no way for it to go back and change the lane.  You would probably have to create something in Subassembly Composer for this.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
raghulan
Thanks I know that, just wanted to know if there is any work around in achieving that. I can always create a full subassebly integrating kerb foundation and lane together.
www.zcodia.com.au
fcernst
just wanted to know if there is any work around in achieving that....
LaneOutsideSuperLayerVaryingWidth
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
raghulan
in reply to: fcernst
 will give it a go.
www.zcodia.com.au
Rail Community
