Civil 3D Forum
Subassembly daylight to surface
1 REPLY 1
djb5000
228 Views, 1 Reply
Its one of those crosseyed C3d days for me-
I dont use assemblies too often and I cant find anywhere to specify what surface I want to daylight to. Everything is showing up in my corridor except my Basicsideslopcutditch daylight line. PLease help!
1 REPLY 1
suntzu2
in reply to: djb5000
I believe you specify the daylight surface in: Corridor Properties > Parameters > Set all Targets.
That should bring up a dialog box showing which assemblies need 'target' parameters such as surfaces or alignments, and you can select the appropriate surface there under the 'Object Name' column.
Rail Community
