What is wrong here?
picture 11:
superelevation (override slope) selected
pictures 22:
superelevation (override slope) is clear
Solved by KMercier_C3D. Go to Solution.
If you want to reference the superelevation slope in the Slope expression you must use SE.LeftLO instead of LeftOutsideLane.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
All of the available API functions for the Subassembly Composer which can be user in expressions are discussed here on the wiki help: API Functions
Pronouns: She/Her
