AutoCAD Civil 3D General Discussion
*Expert Elite*
28 Kudos
Post 1 of 2
Accepted Solution
Subassembly Composer - Varying Depths and Shapes Issue
460 Views, 1 Replies
10-15-2012 10:20 AM
I have a case with the Subassembly Composer where I have 3 varying depths. InsideLane, OutsideLane, and Shoulder. My Base shape below these 3 shapes will not setup properly. I understand why, it's because the varying depths will create a potential step up or down situation depending on the depth of the top 3 shapes. This prevents the definition of the Base Shape.
For the sake of quantities I'd like to create a Base Shape. I could create Base1 Base2 Base3 (one below Inside Lane, Outside Lane, and Shoulder). I would prefer not to for clarity purposes.
How could one approach this? I'm thinking that I need some conditional components to clean this up. I'm not a pro writing expressions (maybe someone can provide some examples of these to assist). I basically need to define the links that define the varying depths between the top 3 depths. I need to create another point and link if the depths vary, and that link needs to be included within the shape definition for Base. Just don't know how to get there, anyone? Many thanks in advance.
Hi Kelly,
In this case, I suggest a way:
  1. To create AuxLink at the bottom of the Top 3 shape.
  2. To compare the Y value (or elevation) of the Point at the bottom of the Top 3 shape.
  3. To use the Max or Min one as the reference of the bottom of the Base Shape.
  4. To use Intersection Point to find other points and finish Base Shape.
In this way, Point API may be used. For reference, the help wiki can be found in SAC Help menu. And there are some tutorial samples in wiki. Hope that will be useful.
I just provide a general idea. I am not sure whether it can be understood and whether it can be used to solved your particular issue. So if you have any questions about that, please feel free to let me know.
8 Kudos
Post 2 of 2
Re: Subassembly Composer - Varying Depths and Shapes Issue
10-17-2012 10:46 AM in reply to: LeafRiders
Hi Kelly,
Tatiana Machado
AEC-ENI Application Engineer
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
