What's the easiest way to update an existing custom SA once it's in the drawing.
For example i have some coding that I'd like to change and this particular SA is in use 10 times in my file in different ways. I used the Subassembly Composer to create the original custom SA.
It's not as easy as saving the file over top of the existing .pkt file, if it was I wouldn't be here. It seems to be behaving like a block would. I need to redefine the Subassembly in order for it to update in the drawing. How is best to do this and is there any tricks to the process. When do i need to open and close Civil in order to apply the new changes.
Do I need to update the SA in my tool palette as well? Any and all information that will save me smashing my computer would be great. Thanks.
Solved by mathewkol. Go to Solution.
